CL-Class (W215) 2000-2006: CL 500, CL 600
Using partial fill of e85 in cl600 biturbo ?
Old Jun 17, 2018 | 06:36 PM
tusabes's Avatar
Mercedes
Hey guys
without guessing , has anyone run full tank or partial tank of e85 in their biturbo m275 v12? Any issues or improvements to a stock car ?
Here in CA, e85 is a dollar cheaper per gallon and octane is. Much higher (110+) than the 91 unleaded supreme we can get here which is the highest octane we can get .
im thinking of running maybe a third tank of e85 plus 2/3 tank of regular 87 octane unleaded . Seems that would result in about 95 octane fuel at far less cost than even regular unleaded gas .
Looking for people who have actually used e85, and any problems or parts Needed to prep the car to use it - not just opinions on what you think of it .
Old Jun 17, 2018 | 07:34 PM
pmercury's Avatar
member
CL
I do, since a while, random
33% is perfect, 45% fine
you have to go in Xentry - ME-SFI 2.7.1 - correction programming - Enrich
the other way is to get your injectors enlarged 33% by a specialist, then you can run 100% E85
both might get you still run a bit poor, but it is fine, just creates head in the cylinder when poor
even better, re-tune your ecu with the larger injectors
if you have i well tuned, you'll get your engine temp 15 C down with 100% E85
then you can tune your turbos up even more and get lots of more HP
Old Jun 18, 2018 | 03:57 AM
pmercury's Avatar
member
CL
specialists I called
fuelinjectorconnection.com
Old Jun 18, 2018 | 03:59 AM
pmercury's Avatar
member
CL
forgot to mention, the ME-SFI 2.+ modules are supposed to auto adjust a bit, but of course it has it limits but it helps
