CL-Class (W215) 2000-2006: CL 500, CL 600
Help CL500 W215 ABC warning light on!
Old Aug 3, 2018 | 04:58 PM
Sam87's Avatar
S65AMG V12 BiTurbo- Designo S63AMG V8 BiTurbo
Hello everyone
I know this is my first post and it might seem as if I'm in here just to get some answers but I'm a car enthusiast and I will be using this site more as I've recently got 2 Mercedes. I've had bmws in the past and still have an m3 but now I'm also a mercedes fan
Recently I bought a facelift cl500 w215 model and the car has done only 63k. The car has had only 2 owners, last one had it for 14 years.
I've spent 3 months now restoring the car to as new condition as possible, inside, outside and underneath. Will make a thread for the work ive done to it soon.
It had a warning light on saying lock passanger seat and I knew that it was a job I wasn't looking forward to doing so I thought I'd leave it as the last thing to do.
I fixed the seat 2 days ago and once i started the car up, ABC warning light was on
I had no idea about this problem when I bought the car as with the ignition on it had no faults and once starting up the car the warning light for the seat would come on and you couldn't see any other faults as it wouldn't let you.
To say I'm upset about this would be an understatement as I've spent so much money and so many hours doing this car up it's crazy and now I have to deal with this problem too!
I've plugged the car in with kts200 (bosch) and the faults that come up are
C1525 unknown fault
C1526 unknown fault
In the cluster once starting the engine up it says
ACTIVE BODY CONTROL
ABC
VISIT WORKSHOP
The warning light is in light blue. Not red
The warning light comes on as soon as I start the engine. Once I turn the engine off and turn the ignition back on, it says no malfunction, only with engine running the light comes on
I've tried to clear the fault and it doesn't let me.
There are no leaks anywhere, the suspension goes up and down as it's meant to. Even if the car is parked for 1 week it doesn't go down.
The sport button makes the suspension a bit harder and you can notice it when pressing the button so it seems like everything is working.
I've checked the linkages front and rear if they were damaged or broken, all good.
I've unplugged the wires and there is no broken wires or any dirt inside.
The fluid level was just below min and I bought some fluid from Mercedes and topped it up hoping the light would go off but after driving the car for 5 miles or so the light is still on.
Has anyone had this problem? What could it be? Anything I can check before taking the car to a Mercedes dealer or Mercedes specialist?
Sorry for the long post, I had to let it out as this car has upset me now. Always liked this cars and I thought I'd buy one but I think I will sell it once I fix this problem too and go for what I've wanted for some time now, e55 amg w211.
The car drives beautiful and plenty of power but this experience has ruined it for me
Any advice or info would be much appreciated!
Old Aug 3, 2018 | 11:47 PM
tusabes's Avatar
Mercedes
The white digital error could be a lot of things , you need the car scanned with Mercedes computer to read the codes . If you keep driving it like that it will turn into the red error and the struts will lock up to protect the system
Old Aug 4, 2018 | 06:33 AM
renault12ts's Avatar
W215 CL500 2005
I've had my car for more than two years now. The white message comes on everytime. I cancel it and drive as normal. No harm has come.
Eveerything works as it should...but one of the level sensors in the front right strut is faulty. That's it. I corrected this by fitting in links and cancelling it out.
If it was to get worse I'd fit a new strut...it hasn't.
Old Aug 7, 2018 | 02:06 AM
willienguyen's Avatar
Merc CL-600, JAGUAR STYPE, HONDA SHADOW, Can-Am Spyder , few of VINTAGE VESPA models
Hi, I'm new here.
Please advise where and how to get 2000 CL600 ABC filter in Sydney Australia?
Any advice would be much appreciated.
thank you
Old Aug 7, 2018 | 02:21 AM
Originally Posted by Sam87
Hello everyone
C1525 unknown fault
C1526 unknown fault
ACTIVE BODY CONTROL
ABC
VISIT WORKSHOP
Hi, i have the same problem!!!!!! please advice and share your remedy for it
thank you very much
Old Sep 17, 2020 | 03:03 PM
nicola185's Avatar
Mercedes CL500
Cl500 abc problem
hi I have just read your post, I seem to be having the same problem abc white warning light Visit work shop could you tell me is this an mot failure as the car drives fine any advice would be very helpful thank you, Nicola
