To buy or not to buy...that is the question
Tusabes, everything you say is exactly correct. The ABC system is merely an aggregation of rubber hoses and rubber does degrade over time. So just like your radiator hose, your heater hose, your AC hose, etc., the ABC system has a limited shelf life and needs to be properly maintained and serviced. Every car that has rubber and plastic parts and is 10 to 15 years old has the same issues.
So you have to decide whether you like the car enough, if it is unique enough, if it is worthy enough, to maintain it in its original condition, or do you just want to treat it like any other cheap $10K car and throw it on the scrap heap when it costs more than a few thousand dollars to maintain.
Personally having owned and lived with the car for 10 years, I think it is worthy enough to be lifetime keeper. In my entire life I have never owned a better, more reliable, more out there, more attractive, more extreme car. Simply put, it was the BEST.
So today thanks to that wonderful thing called depreciation, the CL gives people who cannot afford to pay $200K for a daily driver the unique opportunty to know what it is like to drive a supercar, to take 25 mile an hour corners at 70+, to go from 0 to 60 in 4 seconds, to have the instant gratification of a supercharger, to have “go kart” handling and to do it all in the luxury and comfort of a world class GT car. I did all of that with Zepplin blasting from the incredible stereo but it works just as welll with Bach (which is my friend’s choice who has a twin CL65 to my CL55—of course, mine being supercharged, it was better.).
But if someone views the CL merely as a $10K car that is disposable, that is only “worth” that, that no one in their right mind would spend more than a few thousand dollars on, that they will delete core elements from to save a few dollars, then they wont understand a word I just said. Unfortunately, if you love cars, it is a lifetime opportunity missed.
A Hyundai with hydraulics? Sure, I expect to replace everything within ten years and plenty of maintenance, even throw in some unreliability and I’m not going to be shocked. But being these cars were often $100k+ msrp it’s quite odd they were known to be so unreliable. It’d be different if this wasn’t a production car, but it is
edit- unfortunately, all w215’s owners often spend thousands on systems besides the Abc, it’s not a matter of being cheap... These cars are largely reliable outside of AbC, but still plagued with metal corrosion, failing vacuum lines/pumps, expensive tires, leaky transmission wiring harness, expensive batteries, double the amount of spark plugs of a normal engine, fiberglass body repairs, speedometer cluster issues, leather maintenance, and lots of other quirks TO BE EXPECTED ON A $100k Msrp car. All extremely common issues/costs on the w215. Our opinion is just that the unreliability and maintenance costs of ABC from the early 2000’s is illogical even for a $100k car
I think the best way to put it, is that lots of w215 owners are largely disappointed that a world-class car can be largely unreliable.
You have no idea hence what you speak. The CL was the most reliable car I ever owned and I probably spent no more than $3K in any year over 10 in maintenance.
However, as the Lord, please do dispense your Kool Aid to your disciples.
You are not related to Jim Jones are you?
I have four ABC cars currently and all retain their abc systems so I am genuinely interested in your abc experiences
i was hoping you’d answer my question about what abc service you had during your ten year term with your cl55. Did you have any accumulators changed , any struts Changed , any hoses changed , any valve bodies changed , and how many fluid and filter changes during that time ?
I also know that i never had an ABC failure or any other catastrophic event (the worst being that one of my headlight switches once failed and i had to drive around with 1 headlight for a few days while they got a new part). I was also periodically wearing out the transmission mount because I liked to go fast from every stop light.
Truthfully the biggest cost of ownership was tires (about $2000 every 10K) and gas (less than 9 miles to the gallon). But that was just me being me.
Over my 10 years of ownership i worked with my mechanic and we tweaked the suspension based initially on some Brabus specs and then we went from there. By the time we were done i had an outrageous handling car that could keep up with my Ferrari. The biggest thing for me was that it had that “go kart” tight feeling instead of the factory set up which is very “soft”. But the key was this was achieved without sacraficing ride or comfort. Also at the end of the day it only involved low cost lowering links, wheels, tires and alignment mods (though plenty of trial and error). Absolutely no body or frame mods.
I would be happy to share the final specs if you are interested.
I love how you have elected yourself as Lord of the Flies with all the “we” and “our” stuff.
Anyways, Its clear that I understand these cars better than you, while again, you claim I do not understand when I have actual experience with everything I’ve stated. I’ve driven both abc w215’s, and a w215 with coilovers. You simply have not. Case closed. You are the one speaking from ignorance and arrogance here.
You came into this conversation claiming these guys should just own Toyota’s, and comparing their cars to Third world country taxi cabs, simply if they don’t want to deal with Abc issues? but later you argue “these are incredibly complex cars”. It’s very clear you don’t know much about these machines besides sales brochures, magazine articles and second- hand opinions from your Indy mechanic who has amusingly already made a small fortune from you, and seems well on his way to cash out on a full Abc rehaul here soon. I’d be sure to tell you to keep the w215 with Abc if I was him too
me? I’ve upgraded w215’s to AMG engines, transmissions, brakes, lorinser body panels, upgraded the Bose sound system, replaced The suspension, electronics, engine components and so forth all myself. I can tell you the exact size nuts and bolts for everything on this car....
you? You consistently get milked by your mechanic while reading Car and Driver magazine in the waiting room... get on your smartphone to speak to matters youve not engineered nor experienced, and denounce those who’ve made the more logical decision to ditch the Abc system
also im starting to realize, you are speaking of your Airmatic S class in regards to a non ABC w215 - having bad handling? What an asinine assumption to think you understand a coilover converted w215 because you’ve driven an Airmatic W220 🤷*♂️
Lastly I don’t know how much more clear I can make this. You are certainly in the minority as someone who has been able to avoid major ABC issues. Take some time to actually read through these forums, and learn some things about these cars and you’ll probably realize you are speaking from a stance of pure luck, ignorance and arrogance . Good luck with your Abc and I genuinely hope it does not fail on you at speeds of 70mph+ because that is a risk you are proudly undertaking. Plenty of people have done this but it looks especially asinine coming from someone who denounced removing the Abc system.
#32
-you’ll want to replace the stock 10micron Abc pump filter with the new 3 micron filter
-very regular fluid changes with a real
mercedes mechanic who can run the “rodeo” test afterwards and also properly bleed the system
-ANY signs of seapage or leaks from any hoses or struts means it’s time for replacement
-the system uses rubber hoses to account for the fluctuations in hydraulic pressure involved in these systems unfortunately. So i would change these hoses every 7-8 years for the sole fact that one hose bursting can subsequently cause an Abc pump failure.
-consider changing aged pumps/valves/accumulators even before they get a chance to fail
-cleanliness when servicing the abc system is important as well, just like working on transmissions. They are very sensitive to dirt/etc
these systems are alike to Hvac systems in that when the main pump goes bad, it often sends particulate and shards throughout the rest of the system, effectively grenading the system. Any Abc warning lights should be thoroughly investigated in My opinion, even if they seem to resolve themselves. You’ll find weaping hoses, struts, pumps and reservoirs far before you will see any errors in my experience
edit- this should have been covered under the recall, but on the w215 in particular there was a factory installed hose that ran over the transmission bellhousing and would leak/burst and cause the car to catch on fire. It’s worth double checking your service records to make sure this recall has been done .
#33
Also, while the ABC system is a great handling system, it can certainly be tweaked and made even better. With so many ABC cars you might want to try it.
RonCL55 (11-07-2018)
#34
im sure Ron’s mechanic genuinely has better expertise on these matters but from what I’ve gathered -
I’m aware of the recall and only one of my cars is affected . None of the hoses that burst were the recalled hose .
my cl600 had 2 or 3 hose bursts during the prior owners care , none yet during my ownership .
#35
Well - I agree with RonCL55 - The ABC system along with a 500 plus hp twin turbo V12 with super car performance is what makes these cars! I would never put coil overs on my CL. The CL600 was the most expensive MB you could buy in it's day (apart from the Maybach, which had the same motor). Expensive cars have always demanded expensive maintenance. I have replaced all my ABC hoses with non MB ones, which can take higher pressures and temperatures and cost about 1/4 of the MB price. These have not failed on me. I have also had my block valve cleaned and new O rings fitted (not expensive at all). My ABC works fine and will always stay on the car no matter what.
#36
Starfollower, you offered good insights into maintenance and you are the first one that I have heard of that went the new and improved aftermarket hose route. Makes total sense. Are there any sources or tips that you can offer?
My suspicion is that the coilover route chosen by some is because the CL at its present price point has fallen into the hands of some backyard mechanics who find the car too complex to properly maintain (not criticizing because I used to be one myself). You might be able to offer them some inspiration.
Starfollower (11-07-2018)
#37
Tusabes, it is going to take me a little while to gather all of the information and source references. But i will certainly get it done. It was a fun, low cost project and really personalized the handling of the car for me.
#39
if you buy this car FOR the abc system, that makes some sense to spend the money on it, though sorta illogical. I bought this car for being the car it was, I probably would’ve still bought it without any hydraulic suspension setup.
#40
Thanks ctravis595, I too hate any threads that rubbish the w215 coupes. To me they are one of the most beautiful cars that MB ever made. People still think mine is a lot newer and more expensive than it is! I think opinions by everyone have merit here. If I owned an early version CL500, who's value has dropped drastically - I too would think of a coil conversion to avoid an extra cost. The 5 litre motors and gearboxes are very reliable, so you would end up with a beautiful looking relatively reliable coupe. But - I would not put coil overs on a newer CL600, as I think these cars are future classics (not making many V12's any more - if any??) I wish that all the MB forums would say more positive things about these amasing vehicles!
#41
thats a good point, a lot of you all bought your cl55/cl600 models, even used, for $20/30k and upwards. So spending $5k on ABC every few years isn’t too outlandish, I guess, especially if that was your main cause for buying the car.
My car was an 2002 Cl500 for $13.5k when I bought it. And I personally didn’t buy this car for the ABC alone, I bought it because it was the best car I could buy with $13.5k at the time.
ABC was something I learned about when I bought the car. It was cool to adjust ride height, but I’d already been used to sports cars with stiff suspensions with not much body roll. And as everyone knows, the ABC system still acted quirky over large potholes. So to me it was like “oh hey that’s cool” not “HOLY WOW”. I was largely impressed by the car overall
my cl500 came with the AMG bodykit, nice rims and was well-taken care of with low miles. The car was very impressive and certainly the nicest thing I’d ever bought myself at the age of 19
#42
