CL-Class (W215) 2000-2006: CL 500, CL 600
Hydraulic fluid leak
Old Oct 9, 2018 | 08:56 AM
Andrew Butler's Avatar
2003 CLK 240 Soft Top.
Before I start - I am no mechanic! There is a hydraulic fluid leak from the roof of my CLK just to the left of the rear view mirror and is now dripping through the head lining. I have pulled the plastic cover away as far as I can to have a look and I see dripping of fluid from the mechanism in there! The next step is to remove the plastic cover completely. I will need to open the roof partly to do this. However, I don't want to get stuck with a open roof that will not close. The pump fluid in the boot is half full at the moment. I am waiting for the delivery of some fluid to top it up before I do anything else. Any ideas of how to fix this - easy, hard,costly?
Old Oct 9, 2018 | 07:50 PM
tusabes's Avatar
Mercedes
this guy Klaus will provide you all the parts and assistance you need
https://www.tophydraulicsinc.com/en/
by the way this is the forum for the. Large CL hardtop coupe not the clk
