CL-Class (W215) 2000-2006: CL 500, CL 600
Engine Mount Replacement-- How Necessary?
Old Apr 28, 2019 | 08:14 PM
nine9sixer's Avatar
w215
Hello All,
On my 02 CL500, my engine/trans mounts apparently are all collapsed.
Repair cost is $1200.
Only symptom would be slight vibration at idle with brake applied.
Otw, wouldn't know they need replacement-- car shifts fine and nothing strange upon acceleration, etc.
I know broken mounts could lead to a broken radiator hose, axle shafts, etc.
But is that a rare event or somewhat possible/likely occurrence?
Any thoughts on how likely I could have damage if i waited several months?
THANKS in ADVANCE!
Old Apr 28, 2019 | 08:50 PM
MrTracy's Avatar
2007 S550 & 2009 CL63 AMG & 2009 BMW 328i Convertible
Engine mounts
I wouldn't give it a second thought.."Change them!" Differed maintenance on these cars is the most expensive maintenance when not done. The tolerances are very tight on the V12 engines. I think you are playing with fire.
Old Apr 29, 2019 | 02:32 AM
pmercury's Avatar
member
CL
Originally Posted by nine9sixer
Hello All,
THANKS in ADVANCE!
you can do it yourself
and you can find the mounts new on old stock sometimes on ebay
I paid both 150 $ new a pair from ebay broker
you can wait for a good occasion your engine mounts don't go to metal on metal when the hydrolic fluid part colapsed
it is still some rubber on rubber
but think about replacing them within the next 60 days
pmercury's Avatar
member
CL
search this forum for the do-it-yourself
Old Apr 29, 2019 | 03:09 PM
nine9sixer's Avatar
w215
Thanks, guys.
Looks like i'll be replacing these suckers soon.
Been contemplating the DIY route but seems like i'd need a lift or engine crane, both of which i don't have.
Old Apr 30, 2019 | 09:10 AM
ctravis595's Avatar
2002 CL500 to CL55 conversion
When I bought my CL500 it needed engine mounts, All was generally okay but if you gave it full throttle you could literally hear and feel the entire drivetrain jolt against the firewall (I’m guessing it was the firewall), if you need any further convincing, just give your car a lot of throttle and I’m sure you’ll prioritize your engine mounts again lol. I had my indie mechanic replace the mounts as I hadn’t started wrenching on this car yet
Old Apr 30, 2019 | 10:49 AM
nine9sixer's Avatar
w215
so, I do drive the car pretty aggressively (car has yellow speed coilovers and handles extremely well) and haven't noticed any strange movements (although admittedly never have gone full throttle).
I've raced cars at the club amateur level so have an OK feel for car balance and movement and nothing seems unusual.
as mentioned, other than a slight vibration at stop lights, don't notice any other symptoms.
but i'll be getting the mounts replaced as everyone suggests.
thanks!
