Hydraulic Suspension Right Front sits high - is that normal?
1993 400 SEL , 2002 CL500
Hello Members,
I have a 2002 CL500.
My right front fender sits almost 4 inches from the tire ( 245/45/18). Is that normal height?
The SHOCK or if I push down on it (range) is working. But it just sits high.
The left side has a bad shock and sits low. When car runs it comes up, but not as high as the right front fender.
Any suggestions would be great. Thanks in advance!
Plutoe,
Do you know if you bleed the Hydraulic fluid from the shock,will the car go down?
Do you think the shocks are in a locked state?
Thank You
Thank You
