CL-Class (W215) 2000-2006: CL 500, CL 600
Red warning move transmission lever to park
Old Mar 8, 2020 | 07:04 PM
wewmbw's Avatar
2006 CL500
Hello
Today I was putting my 2006 CL500 into the garage when I got a red warning message "move transmission level to park". The transmission shifts into Drive and reverse and car moves (Did not take out on the street). Has anyone seen this? Not sure if the car is safe to drive to the shop to have it checked, or need to have it towed. If transmission is put into park warning will go away but comes back if taken out of park.
Thanks for any help. The car only has 7800 miles so the transmission should not have gone bad.
Old Mar 9, 2020 | 05:26 AM
pmercury's Avatar
member
CL
electrical I have that popping up once in a while after I removed the key . investigating
Old Mar 9, 2020 | 05:44 AM
GBsSL55's Avatar
2004 SL55
My new to me SL55 did that once to me. I was just moving car around on driveway when it happened. I had my driver's door open when it did it. Maybe your door wasn't shut all the way. Car detected door not fully closed and gave you that warning?
Old Mar 9, 2020 | 09:12 AM
wewmbw's Avatar
2006 CL500
Ok so this is not something wrong with the transmission. The car should be safe to drive.
Old Mar 9, 2020 | 09:21 AM
pmercury's Avatar
member
CL
It is 100% safe to drive
