M113 egr delete diy
one quick and useful solution to egr problems, or anybody looking to keep the intake manifold cleaner, is to mock up some block off plates with scrap aluminum/steel. I removed the egr altogether but there are two ways you can go about this and not experience any pesky check engine lights
one way is to bridge the two wires running to the egr with a 30ohm resistor, thus tricking the ecu to believe the egr is still functioning
another way is to insert block off plates underneath the egr valve, and leave the egr valve plugged in to the ecu.
ive tested both methods and both ways work for removing the egr system without any check engine lights for less than $10. If you simply unplug the maf you will get one code p0403
edit: I recommend using a 10 watt resistor for the 30ohm resistor. The rating will loook something like 30ohm 10 watt resistor , lower wattage rating resistors may not hold up over time
if you use too low of a wattage resistor, it can burn out and will cause p0443 and possibly some o2 sensor heater codes. If this happens you’ll have to replace the weak resistor and replace the blown fuse related to the ecu. On my car it was fuse 30 on the passenger side fuse panel
