CL-Class (W215) 2000-2006: CL 500, CL 600
Instrument cluster
Old Jul 6, 2020 | 07:37 AM
renault12ts's Avatar
W215 CL500 2005
Instrument cluster
My instrument cluster has had a complete failure.
Can I replace the one I have with any other one...or, must the part numbers match?
The problem I have is the label with the part number on has been removed.
Where is the car's mileage stored?
Old Jul 6, 2020 | 08:52 AM
pmercury's Avatar
member
CL
normally yes give me your vin Ill give you the list of compatible clusters
in miles yes ?
Then you must adapt it to your car with adaption takeover in Xentry
The mileage is in the EIS, the shifter and engine module. the cluster just sends and read back not locked on mileage
If you don't adapt it you'll get ------- as mileage in cluster
Old Jul 6, 2020 | 10:29 AM
W215 CL500 2005
in miles yes ?
Hi PM...my VIN is: WDB2153752A046138
The cluster has one speed scale going to 260.
I can, using the menu, switch between mph and kph.
Thanks.
Old Jul 6, 2020 | 12:18 PM
pmercury's Avatar
member
CL
Thanks.
ok
now tell me if you want a USA/UK cluster to replace your euro cluster
or you want to keep your Euro cluster with the KM scale to 260
USA/UK miles clusters
EURO KM cluster
or you might want a AMG cluster that scales to 360 like mine
Old Jul 7, 2020 | 06:33 AM
W215 CL500 2005
I'd like to keep the Euro cluster, but USA/UK one will do the same job.
Old Jul 7, 2020 | 06:49 AM
pmercury's Avatar
member
CL
ok
hold
Old Jul 7, 2020 | 06:53 AM
pmercury's Avatar
member
CL
A2205407747
cheap one here
https://www.ebay.com/itm/2001-MERCED...MAAOSwS4he4j9i
Old Jul 7, 2020 | 06:59 AM
pmercury's Avatar
member
CL
the here all compatible versions with different variants make sure you check if KMH or Miles
Old Jul 7, 2020 | 12:25 PM
W215 CL500 2005
Many thanks PM.
Old Jul 7, 2020 | 02:12 PM
pmercury's Avatar
member
CL
Many thanks PM.
my pleasure
Old Jul 8, 2020 | 11:10 AM
W215 CL500 2005
I picked up a cluster for £90. I hope it works.This is cheaper than the parts needed to effect a repair...even if I could solder neatly.
Old Jul 8, 2020 | 11:27 AM
pmercury's Avatar
member
CL
nice !
not many fail
Old Jul 16, 2020 | 10:08 AM
W215 CL500 2005
New (old) cluster arrived. Found the blown fuse...and it works. Just need it coded to the car now.
Old Jul 16, 2020 | 10:33 AM
pmercury's Avatar
member
CL
best is to put the old back
adaptation with takeover
follow the screen
Old Jul 16, 2020 | 11:30 AM
W215 CL500 2005
follow the screen
Not sure what you mean.
Old Jul 16, 2020 | 01:02 PM
pmercury's Avatar
member
CL
ooops sorry
that post was not for here
you need to hook up your old cluster
then go in Xentry to cluster>adaptation
then adapt with takeover the old cluster coding
it will read
then tell you to replace cluster
and write to new cluster
done
Old Jul 16, 2020 | 01:05 PM
pmercury's Avatar
member
CL
post corrected
