CL-Class (W215) 2000-2006: CL 500, CL 600
Temperature dependent sagging
Old Oct 5, 2020 | 09:15 PM
AZmlcl's Avatar
2000 ML 430 , 2004 CL55
Hello Everyone,
My '04 CL55 has one corner that sags at different rates depending on the ambient temperature. At 70 degrees and above I can leave it in my garage for almost a month before the one corner starts sagging, and it takes about a day or so before it has achieved a "full sag". If I take it to work at colder temperatures (40 degrees or less ) that corner will sag completely in less than 3 hours. Does anyone else have this happen ? From what I've read, it seems that the locking valve is the likely culprit. I haven't pulled it out to confirm that. Is a o-ring / anti-x ring replacement the cure for this ?
Thanks,
AZmlcl
Old Oct 5, 2020 | 11:50 PM
MartinWake's Avatar
CL55
Only one side goes down?
Old Oct 6, 2020 | 10:10 PM
AZmlcl's Avatar
Just the left front . All other corners never sag.
