Sound system
Had a water logged boot which has now been sorted but have a problem with the sound.
Rear sub woofer on parcel shelf works but none of the door speakers.Everything is working fine,cd player but
just no sound from door speakers.
Have been told it is the Bose but does anyone else have any suggestions or it is the amp.
you have pairs of speakers wires there, test them pair by pair with some speaker output sound source you bring to the car
or tap the wires shortly on a 9v battery, if they make a little crack they work
or use a multi meter if you know how to use it
you can get a new amp from ebay for 90$
im interested. . I also had a leak in the trunk and my entire sound went dead tried swapping amps and nothing all dead. I was just gonna replace the head unit and install aftermarket amp and see if I can get it to work. But have. Yet to go down the rabbit hole
