CL-Class (W215) 2000-2006: CL 500, CL 600
Distronic External Malfunction
Old Aug 1, 2021 | 07:38 AM
JasonH1969's Avatar
2001 SLK320 and 2004 CL500
Hi,
The distronic function on my car seems to set okay but after a few minutes of driving it deactivates and posts the message "Distronic deactivated external malfunction". Does anyone have an idea of what the problem could be?
Old Aug 7, 2021 | 05:59 AM
tim687's Avatar
CL 600 '00 5.8L V12
I suggest that you check the connectors at the radar unit. The multi-wire connector, that clips in was lose on one of the clips.
Make sure that you give the connector a quick blow with some compressed air (or use a vacuum cleaner)
Old Aug 7, 2021 | 12:51 PM
JasonH1969's Avatar
Thanks for that, I'll give it a try.
Old Aug 8, 2021 | 04:04 AM
tim687's Avatar
CL 600 '00 5.8L V12
Also, make sure that the sensor is centered. Use the 3 screws at each corner (except one) to center it as best as you can
