CL-Class (W215) 2000-2006: CL 500, CL 600
Whining sound
Old Aug 21, 2021 | 07:50 PM
MartinWake's Avatar
CL55
Whining sound
Hello guys I have not been driving my car too much but when I do I like to downshift to hear the exhaust anyways I have noticed the whining sound that usually happens on all auto cars when downshifting is a little louder then usual. I will post two video links with the sound, hopefully you guys can hear it and point me in the right direction. I suspect its the transmission because it does not happen in park or neutral. My car is a CL55 AMG
Thanks!
Edit, it does do it in park but it has always done this sound
https://youtu.be/ul23BggiMOI⁠
https://youtu.be/EESooOzRRTc⁠
one video is next to a wall the other is not
After further research I am now thinking it could be abc related? I check my fluid level everyday and it does not drop. I have also replaced the front abc accumulator when I got the car.
Old Aug 25, 2021 | 01:46 PM
tim687's Avatar
CL 600 '00 5.8L V12
It honestly sounds like a supercharger of somesort.
Have someone hit the gas whilest you're listing with the hood open is my suggestion
Old Aug 26, 2021 | 04:01 PM
MartinWake's Avatar
CL55
I did it does not sound like that from the front, I think the problem is one of the abc accumulators from what I read..
Old Aug 30, 2021 | 02:35 PM
tim687's Avatar
CL 600 '00 5.8L V12
Whilest researching the symptoms that I currently have, I stumbled upon this
https://mbworld.org/forums/m275-v12-...ml#post6759027
Good luck!
Old Sep 8, 2021 | 11:03 PM
MartinWake's Avatar
CL55
Changed the abc pulsation damper and the sound is still there
Old Sep 15, 2021 | 08:53 PM
MartinWake's Avatar
CL55
Alright I took off the pan and I do not see any flakes of metal. The filter is also clean. Could it just be the conductor plate now? It did every symptom of that.
Video 1:
Video 2:
Old Sep 19, 2021 | 06:18 AM
ChrisVannoy's Avatar
2002 Cl500
Could be torque converter
