CL-Class (W215) 2000-2006: CL 500, CL 600
W215 M275 - Vacuum Lines
Old Nov 19, 2021 | 03:22 PM
ktos92's Avatar
W204 C200 OM651 ED125 / W215 CL600 M275
Hey Guys,
i am doing quiet a lot of work to our CL. I have the top of the engine management taken out and I have all of the vacuum lines in front of me. I was thinking to replace them but I am facing a dillema. What size of the silicon hoses should I choose. I am referring to the internal diameter. The plastic lines I think are about 3mm and they are using connector adapters to fit into the diverter valves and intake etc. Each connector on the sensors or intake is 6mm. So the question is - what size of the vacuum lines to use. Does it really matter? Should I use smaller one as ODM and use adapters - it makes things a lot more complicated.
Old Nov 20, 2021 | 03:48 AM
ktos92's Avatar
Originally Posted by Plutoe
why FA with homemade S go here for the correct parts, if you need a second job there are millions of jobs available------Mercedes-Benz Electronic Spare Parts Catalogue Online
Plastic lines are no longer available at the dealer
I know a lot of people have swapped them for silicon as they are a lot more durable
