CL-Class (W215) 2000-2006: CL 500, CL 600
Star (1.1)-1.501.9558 initialization error
Old Jan 1, 2022 | 01:37 PM
tim687's Avatar
CL 600 '00 5.8L V12
I can't connect to my car anymore. I tried loads of different things but I can't get it to work.
I must say that the connection between the multiplexer and my car is not very sturdy. A slight bump and the green led goes off.
Also, I accidentally shorted the positive battery lead to the chassis at the right footwell near the starter relays. My OBD-II scanner works fine though.
I'm using 2010.1 software, which used to work out of the box.
I am using a C3 (marked as Part D4 from Actia)
Old Jan 8, 2022 | 09:57 AM
tim687's Avatar
CL 600 '00 5.8L V12
Turned out you should not run the software in a VM, just run it on a real laptop. That works 10 times better
