CL-Class (W215) 2000-2006: CL 500, CL 600
4 FRONT SUSPENSION HOSES and ABC RELIEF VALVE REPAIR/REPLACE
Old Mar 15, 2022 | 03:17 PM
whjresq's Avatar
2004 CL500; 2010 S 63 AMG; 2001 CLK430 Convertible Designo,; 2012 CL63 AMG Black on Black Designo
Hello
My 2004 CL500 front left ABC failed leaked out at that location. I got a quote of about $1500 for this with no guarantee that it is not some other problem:
PART: 220 320 08 58 PRESSURE RELIEF VALVE - FOR HYDRAULIC SUSPENSION NEW
PART: 2209978282 HYDRUALIC HOSE NEW
PART: 2203200272 HYDRAULIC HOSE FOR SUSPENSION LEFT SIDE NEW
PART: 223201372 HYDRUALIC PRESSURE HOSE LEFT SIDE NEW
PART: 220998582 PRESSURE HOSE HYDRUALIC LEFT SIDE NEW
PART: 2203270215 ACCUMULATOR FOR SUSPENSION NEW
LABOR: BUELNA, REPLACE ACCUMULATOR AND RELIEF VALVE LABOR
LABOR: BUELNA, REPLACE ALL 4 HOSES FOR LEFT SIDE SUSPENSION LABOR
Is this something I can do -- or would I be better off just converting to strut master suspension?
I just did valve cover gasket, plugs, wires and coil packs plus inner and outer tie rods and 4 oxygen sensors - so id like to fix and sell to recoup the investment
Old Mar 16, 2022 | 05:05 AM
tim687's Avatar
CL 600 '00 5.8L V12
It really depends on how handy you are with tools.
You can do this yourself, but I highly recommend getting access to WIS (the required documents are available on the forum if you search on here for a great while) and DAS.
Regarding DAS, I only just got it myself. I was always like, yeah I can do without, but no you can't.
I assume that the front left ABC hose bursted?
If so, how far did you drive your car before shutting down the engine?
