CL-Class (W215) 2000-2006: CL 500, CL 600
Fuel corrosion, what would you do
Old Sep 8, 2022 | 03:56 PM
Fredrd's Avatar
W215
2004 cl 600 38k miles
what would you guys do? Mercedes wants to replace everything in the fuel system. Never had an issue with this car before until A no start
Old Sep 8, 2022 | 08:30 PM
calgary's Avatar
2001 Mercedes CL500 2006 E350 4-matic
38.000 Miles..??? With that low mileage I would try and get everything repaired that is required and keep the car.
Old Sep 8, 2022 | 09:09 PM
Fredrd's Avatar
W215
Dealer wants 7k, I asked them to take a sample of the fuel rail, because the sample they took was from the rear. If the fuel rail looks clean I just want to replace the tank, sending unit, pump, filter, and reverse flush the line from the front
Old Sep 9, 2022 | 03:25 PM
ejenner's Avatar
CL500, W212 e350 mega-spec
You should go somewhere else. I think the dealer isn't using experienced technicians. If they're saying 'replace everything' that's being deliberately over the top. An independent mechanic will do a proper diagnosis and get it fixed for you. It won't be cost free and it might take more than one attempt but it may well come out under $1000 instead of $7000. If it has a plastic tank it won't require replacement, just cleaning at worst. Filters are there to stop crap going through the system so replace the filters. Should be fine after that.
Old Sep 12, 2022 | 03:34 AM
tim687's Avatar
CL 600 '00 5.8L V12
I'd definitely replace the fuel tank, flush the fuel lines and see how the fuel rails is doing before even attempting to fire up the car.
If the injectors are clogged you'll have to clean or replace them.
I was hoping that the gas tank would be made out of aluminium, not sheet metal
