CL-Class (W215) 2000-2006: CL 500, CL 600
W215 replace door control module
Old Oct 22, 2022 | 01:50 PM
sandman1572's Avatar
CL500
Hi All.
I have a couple of queries for forum members on here - both related to the title.
1) I am trying to find a replacement drivers side door/seat control module for my CL500 (2005 model). The part number on the existing one is: 215-821-12-51. Does anyone have any idea where I could search to find one?
I naively ordered what I thought was the right one a few months ago, but turns out it was for a LHD car, so when I fitted it only the passenger side features worked. I'm not getting a whole lot of luck searching that part number online either, so I wonder if the part has been upgraded and the number has changed??
2) Second question I have is - how the hell do you quickly/easily unhook the electrical plugs from these units? When doing the replacement I mentioned above - some were easy, and some were almost impossible to remove. I reluctantly had to resort to using pliers and in doing so bent some of the plastic plugs. I'm thinking there must be some sort of special tool to do this? I bought a set of picks/hooks off amazon - but no luck using those. Maybe there is an order in which you are supposed to release them?
Old Oct 28, 2022 | 05:02 AM
INEEDIT's Avatar
CLK430
Bump… hope you find your answers.
Old Oct 31, 2022 | 03:21 AM
tim687's Avatar
CL 600 '00 5.8L V12
I think the DCM should be programmed to match the location that it needs to operate. Get to somebody who has SDS/DAS.
To unhook them, you just click in the little lever that is at each connector. Pretty easy to do
Old Oct 31, 2022 | 05:15 AM
BenzNinja's Avatar
Former Vendor
Originally Posted by sandman1572
Hi All.
post your vin and I will list you the right module
as said by a member here, might need programming anyway
then, if you imagine maintaining your car with a MB system you are dreaming
you might want to get one, msg me
and no there is no special trick to unplug
just use a tiny screwdriver to help if stuck
