Leaking ABC Hose. Part Number?
I recently noticed leaking hydraulic fluid coming from my CL55. Lucky I caught it as soon as it started.
I pulled off the cover to check, thinking the valve block must have lost a seal, but that wasn't the case. Next I check the clamps, they are all tight. Finally I turned it on and checked the hoses, all looked good, however the rubber part of the hose has a pinhole and is spraying. It looked small, but its pushing out a lot of fluid. I quickly shut the car off again.
Any idea the part number on this hose connected to the REAR valve block on the LEFT (drivers) side, and if it something I can fix myself in the driveway?
