CL-Class (W215) 2000-2006: CL 500, CL 600
ABC Issue
Old Mar 17, 2023 | 01:50 PM
Kevin OB's Avatar
CL 500 SL500 SL 280
ABC Issue
I replaced the ABC pump a reconditioned one( from the Netherlands( I am UK based it was purchased April 2022 ,since then I have only done 1500 miles the car decided to sit down on all 4 corners took it to the shop on a recovery truck they put on machine was saying pressure to low Component Radial piston pump Defective ) spoke to the company in the Netherlands they offered me a 100 euro discount on another pump (NO warranty ) even thought only done 1500 miles with full evidence they said sorry about this, anyway I started the car at the garage pressed the ABC switch it rose on all sides to the max height now it will not go down it is still at full height there are no leaks.any thought on this have any one else had this issue,I am just hoping not the pump.
Old Mar 20, 2023 | 04:27 AM
tim687's Avatar
CL 600 '00 5.8L V12
Do you have access to DAS?
Old Mar 20, 2023 | 02:07 PM
Kevin OB's Avatar
CL 500 SL500 SL 280
Yes ,car is still on high setting the company ABC Specialist says it could be the pressure sensor
Old Mar 21, 2023 | 12:26 PM
Kevin OB's Avatar
CL 500 SL500 SL 280
I did reply yesterday not on the thread
