CL-Class (W215) 2000-2006: CL 500, CL 600
2003 CL500 - Key not turning
Old May 25, 2023 | 03:14 AM
clbandit's Avatar
W215
Unhappy 2003 CL500 - Key not turning
I've had this baby for 20 years. It's my pride and joy. I left her alone for an extended period of time (6 months) without starting her up. Battery was completely drained. Got a new battery and put it in. Car doesn't respond to the key fob anymore, windows will not go down when opening the door, no electronics really work.
First thing I notice is the ODO will show the mileage, then start blinking dashes. If I put the key in the ignition, it will not lock and I can't turn it.
I've checked the key batteries, all are showing proper 3V so they are solid. I've left the key in the ignition for a few hours, still nothing. I checked all of the fuses (not relays) and they seem to be just fine. I'm at a total loss - can anyone help me figure this out?
Thanks for any info!
Old May 25, 2023 | 03:30 AM
tim687's Avatar
CL 600 '00 5.8L V12
Did you swap your battery or did you recharge the existing battery?
Disconnect the battery for a while and try again
Old May 25, 2023 | 10:34 AM
clbandit's Avatar
W215
Old battery wouldn't hold a charge - it was a few years old and sitting dormant really did a number on it. Ended up swapping it out for a new AGM battery.
I've disconnected the battery and left it off overnight, just reconnected and tried again. Still no luck. Key does not do anything when inserted into the ignition.
