2003 CL55 AMG Supercharger Pulley bearing replacement
However, when I pulled the pulley using a breaker bar and unscrewed the retaining bolt, the washer with the two holes for the registration pins fell off and disappeared somewhere underneath the engine. Worse is that both the pins were sheared off. See pictures.
2 questions.
1. How can I replace the pins? Are they loose, such that I could pull what's left out and replace them, or are they a part of the clutch assembly? (I'll keep looking for the washer or just buy a replacement.)
2. Can I drive the car with the supercharger disabled? It's not doing anything under 2700 rpms anyway, right? Or would my air/fuel mixture be completely off with it disconnected? Possibly there's some oil flow or lubrication happening even when it's not engaged?
See pics. Any suggestions (or moral support) are welcome!
Sheared off alignment pins. The washer fell before I could catch it.
Pins were sheared clean off. I used a breaker bar, and don't think that was the cause, but am not sure. The washer that fits over this fell and I haven't yet found it. Will try fishing with a magnet.
Spent an hour with a magnet and light trying to find that washer that goes between the pulley bearing and the bolt, and haven't been able to find it. It fell straight down, but is nowhere to be found. Was unable to remove the remainder of the pins left in the shaft either.
Any idea where I can find a spare washer? I don't know how essential the pins are, if they are involved in driving the compressor or simply an aid to mounting the washer and locking bolt.
