Fuse boxes location cl600 2000 - not where it supposed to be
Hello,
i need to replace the fuse for the instrument cluster (lost the backlight then went dark, sent my dashboard to be fixed, got it back and now need to replace the fuse).
Documentation I found says it’s in the front on the side of the door opening. I opened. Nothing. On the other side as well
I do have two boxes in the front engine compartment and one in the left passager back seat.
thanks for the help
There was one component that had a fuse at the back of the unit, I can't remember if it was the command or the ICM.
Regarding that magic fusebox, it should be there. It's there on my car at the passenger side (LHD)
thanks!
but it’s not there on my CL600 2000.
I’ve uploaded 2 of my fuse boxes. They don’t seem to follow exactly the diagrams I found online. The earlier version might be different.
Rear passenger fuse box cl600 c215 2000 Driver side engine bay fuse box (lhd) c215 w215 cl600
thanks!
So bottom line : There’s only 3 boxes in this generation of CL600. For the dashboard , it’s in the one engine bay, driver side. On a funny side note, the same fuse that controls the dashboard cluster, also controls the trunk release 🥸.
