CL-Class (W215) 2000-2006: CL 500, CL 600
2005 CL55 AMG: Persistent Trunk Noise
Old Apr 10, 2025 | 01:41 PM
ramboboujee's Avatar
CLK430
2005 CL55 AMG: Persistent Trunk Noise + Shifter Locked Issue
**Car Details:**
- 2005 CL55 AMG @ 155k miles
- Running on coilovers (previous owner converted from ABC)
- Horizon Blue color
**Parts Already Replaced:**
- Front suspension overhaul (removed driver side sag issue)
- Lower ball joints/control arms
- New front rotors
- Rear lateral tie rod thrust arms
- Trunk support struts
- Upper coilover bolts torqued to spec
**Issue #1: Persistent Trunk Noise**
I'm experiencing a loud noise coming from what sounds like the upper trunk area. The noise is particularly noticeable when going over bumps. Initially thought it might be the trunk struts, but replacing those didn't solve the problem. The noise seems to originate from the upper trunk area rather than from the actual suspension components.
I've already checked the basic suspects: trunk latch, loose items in the trunk, spare, etc. The noise persists and is quite loud - definitely not just a minor rattle. I've heard this could potentially be related to the rear subframe bushings or possibly remnants of the ABC system (though all ABC components have been removed and converted to coilovers).
**Issue #2: Shifter Locked in Park**
While working on the car, I jacked it up without setting the parking brake. Now my shifter is locked in Park and won't move. I'm guessing this is related to the shifter interlock system getting confused about the car's position. Has anyone dealt with this issue before? Any suggestions on resetting this without requiring a tow to a dealer?
Any insights would be greatly appreciated. This is a great car and I'm working through the issues one by one, but these two have me stumped.
Thanks in advance!
Old May 13, 2025 | 09:30 AM
CLK430
update to this post. I found out it was the rear struts/shocks apparently the old coilovers on the car that were swapped when I bought the car started failing
