CL-Class (W216) 2007-Present: CL 500, CL 600
W216 cl600 brake caliber on a w216 cl500
Old Feb 1, 2017 | 02:57 PM
Miladm's Avatar
CL 500 (w216)
Hi,
Does these parts on the pic fit directly over on my cl 500 without any modification?
Appreciate your help!
Old Mar 2, 2017 | 07:31 AM
Benztech777's Avatar
2007 Mercedes Benz CL 550
If you have access to a Mercedes EPC ( electronic parts catalog ) you can compare the strut to caliper parts. If the strut is the same and the only difference is the caliper and mounting bracket then you could put it on physically. But you need to consider the balance of front to rear braking? If your going AMG you should do it all. Also check to see if the hoses are the same too. Good luck! I once had a Volvo I put a Chevy 350 engine in it. I replaced the front rotors to 11 inch from 10 inch and I didnt experience any issues but that car was an 84 with standard brakes and no electronic controls.
