CL-Class (W216) 2007-Present: CL 500, CL 600
front strut removal problem
Old May 6, 2017 | 06:47 PM
ire32's Avatar
2009 cl550
I am having a problem removing the bottom of the strut from the lower control arm. Can anyone recommend what to do? I have followed the directions for the Arnott replacement and am stuck. Thank you.
Old May 8, 2017 | 11:05 AM
arnottdoug's Avatar
Former Vendor of MBWorld
MERCEDES-BENZ CL-CLASS
Here is a video Arnott just released for the rear of the W216 & W221
- Hope is helps. If not - give our tech support a call at 321-868-3016 or email info@arnottinc.com
Old May 12, 2017 | 02:57 AM
ire32's Avatar
2009 cl550
Thank you for your response. I was replacing a front strut. The problem was separating the strut ball joint from the lower control arm. Needed a tie rod ball joint separator. The Arnott instructions do not tell you this and I did not find any video from Arnott for the W216. The instructions simply say to separate the ball joint from the lower control arm. The W221 video has a different mount at the bottom of the strut. I had to reattach the bad strut to drive to Meineke and have them remove the OEM strut and replace with the Arnott strut. They charged $220.00.
