CL-Class (W216) 2007-Present: CL 500, CL 600
How do I access the brake lights on 2010 CL550
Old Jul 31, 2017 | 09:46 PM
55proof's Avatar
CL550 & CL55 AMG &S550 COUPE
Exclamation How do I access the brake lights on 2010 CL550
Need help!!!! When I start the car a message pops up,CHECK RIGHT BRAKELIGHT.
I checked it and the lights are out, I need to know how to access the bulbs.I called the Stealership and they informed me the lights are a led strip and I would have to purchase the bulb harness(land support)
I know I have to access the panel thru the truck, but I don't know how and the Stealership is charging $140 to change the the bulb harness 1 hour is minimum the charge for all labor, I need to know is this minor job or should consider letting the do this:confused
Old Feb 22, 2018 | 10:05 PM
55proof's Avatar
Thanks����
Old Mar 8, 2018 | 01:22 PM
lkchris's Avatar
'10 CL550, '12 GL550
What you will need looks like #20 in the illustration. Bulbs are not replaceable individually.
Old Mar 11, 2018 | 12:34 PM
abqhudson's Avatar
2014 e350
Originally Posted by Plutoe
First you have to define the correct part number-----purchase the part--then install---if you do not have answers to those thoughts then someone else must spend their time looking\doing for you---that's what the 140 is for. What is it that you do or do not understand.
Absolutely no help.
