CL-Class (W216) 2007-Present: CL 500, CL 600
2012 CL550 Turbo Wastegate Solenoid A - Check engine light
Old Jul 9, 2018 | 04:30 PM
dja65's Avatar
SL550
Hi Folks!
I have a 2012 CL550 with approx 70k miles.
The check engine light came on last weekend and after running a scanner on the OBD it shows up with the following fault...
P0243 - Turbo/Supercharger Wastegate Solenoid A
Other than take it my local dealer (Raleigh, NC) I wanted to check with y'all to see if anyone has seen this before and if its a known issue or if its a simple repair.
Any ideas or suggestions to try and narrow the fault down would be greatly appreciated.
I'm relatively technical / handy, but need some help to figure this out without spending huge sums with the local dealer.
Thanks in advance
David
