CL-Class (W216) 2007-Present: CL 500, CL 600
Analog Clock not syncing with command clock
Old Dec 5, 2018 | 10:22 AM
vbuckley_ie's Avatar
CL 500
My 2007 CL 500 analog clock is not syncing with the command clock. I used to set the time on the command and the analog clock would then spin and end up with the correct time. The command clock is taking the time from the Sat nav system. If i disconnect the battery the analog clock will revert to 12.00 and start working from there. I am told many W216 cl's are having the same problem? any ideas?
Old Dec 6, 2018 | 10:22 AM
JMKSAIL's Avatar
SL500 CL600 Carlsson
Yup, my 2008 CL600 now doing this after DST time change!
looking for an answer also
Old Dec 7, 2018 | 12:58 PM
PhoenixOp's Avatar
2002 Mercedes Benz SL500
Thumbs up
Mine also gave me crap during the time change, but I kept trying it and a couple of days later it magically worked! WooHoo!
Don't give up - out will it!
Old Dec 9, 2018 | 03:40 PM
TheCLguy's Avatar
CL63
Even my 08 CL had the same problem. But kept playing around and one day it fixed itself....idk but I think its turning into a common issue at this time...probably something to do with the computer system...who knows
Old Dec 10, 2018 | 04:59 AM
CL 500
Hi Guys.
Got a work around from another forum. Leave the car over night. first thing in the morning, start car and within 1 minute go to command, vehicle, vehicle settings, and set the time. The analog clock will move to the time you set. You have only about one minute to do it before the Sat Nav system collects the "correct time" from the satellite.
The date is still wrong but this does not worry me as it is not visible.
Old Dec 10, 2018 | 11:00 AM
PhoenixOp's Avatar
That brings up another question. How do you set the date???
