Selling my 2007 CL600 (Under Warranty!!!)($25k of Repairs)
THIS CAR IS A UNICORN and impossible to get with a warranty. No need to worry about any major repairs.
Here is a list of what I have done to it along with regular oil changes, brake flushers, coolant refills, etc: (I may have missed some things)
All CL600 replaced parts:
Main pulley
Idler pulley
Water pump
Transmission service
Side trim piece replaced (fell off)
Left and right side coil pack replaced
Spark plugs replaced
Driver seat handle function for rear seat part and trim cover replaced
Soft close doors driver side actuator replaced
Mercedes Bluetooth adapter puck replaced
Oil Cooler leak added part
Control arms
Oil cooler replaced
Radiator hose resealed
New intake installed
Brake vacuum leak, corrected
Oil temp sensor replaced
Secondary air valve reset
Air dynamic seat connector replaced for both seats
Secondary valve injection part replaced
Power steering reservoir replaced
Fixed trunk operation and lights
Transmission mount replaced
Replaced secondary air valves
New valve covers
Replace regulator for AC
Replace changeover valve
Oil cap seal
Repaired coolant
Repaired coolant leak
Rear main seal replaced
Driver side seat bladder replaced
Head gasket job, cylinder heads
I will let it go for $25,000
If you have any questions or want more photos of the car, please don't hesitate to call or text me at 502-407-7066.
Thank you.
