CL600 Location of fuse and relay for intercooler pump
I'm getting conflicting information on the fuse location and relay location for the intercooler pump circuit, which is circuit "M44" I believe. Can someone please direct me to the proper place?
Bonus marks for telling me which relay pin to ground or bring to 12V in order to close the relay to test the pump.
Thank you!,
Greg
P.S. I also recently purchased a Zurich ZR-Pro scanner on sale at Harbor Freight. Under ECM->Charge Air Cooler->Activation, there's a way to turn on (F3) or off (F4) that M44 relay. But it doesn't work ... returns to the previous page rather than doing anything. I think it's a bug in the Zurich software rather than a problem with my car, and have reported it in Feedback to Zurich. But that's likely to take a while to be addressed, and I need to get my car back together. But of course I want to test the pump first, and hence the need for the fuse and relay location.
By the way, I finally figured out for myself (reading lots of other forum appends here and elsewhere) that for my 2009 CL600, the charge air cooling pump fuse is #116 (which is in the fuse box behind the rear seat armrest) and probably (still not 100% sure) relay "Q". But of the seven relays on that circuit board, "Q" is the only one that is physically impossible to get to with the board in place.
So I gave up, put the car back together, and took it out for a drive to get the turbo on boost and the charge air heated up. I monitored it with the scanner while driving and it never got over 145F. And after returning home and pulling off the fill cap (carefully!), I could clearly see the fluid moving. I also used a large tight-fitting funnel to fill up with Zertec and left it running for a half hour or so as the bubbles percolated up through the funnel and more Zertec replaced those bubbles.
