W216 CL600 "Side Marker Light" how to remove?
I started receiving a "Right Side Marker Light" error.
I turned on my lights and the orange marker pass side furthest up on the headlight assembly is out and the lower long flat light is out also, that's under the main headlights.
No problem, Ill just change it out....errr not so fast.
I pulled back the pass side inner plastic wheel well liner , spent an hour trying to find the bulb socket and from engine bay , cant figure it out.
Do I need to pull the headlight assembly? PIA
thanks for any tips
thanks for any tips
One of the lights is on the bottom of the headlight assembly and can only be accessed by removing the entire headlighr. It's held in with a screw so it's not a case of just trying to reach in there. The 2nd bulb that's on the bottom can be accessed by removing the fender liner but it's a major pain.
