blower
Blower motor
blower motor I replaced the regulator and the blower had been previously tested. So now I need to check the fuse.
If your old blower has signs of rust on it, or wetness then make sure you check the drain hole outside by the firewall under the little grille cover. If this drain blocks and water collects in this space it will leak onto the blower motor and can cause issues.
Just a heads up. 🙂
Just a heads up. 🙂
Chebahawk (06-16-2020)
