CL-Class (W216) 2007-Present: CL 500, CL 600
ABC problem
Old Sep 20, 2020 | 08:38 AM
IMOTSKA KRAJINA's Avatar
cl 550
Question ABC problem
Hello
I have a cl 550 2007 year. I bought a new ABC pump and valve damper, cleaned the system, new oil and filter, but i didnt fix the problem. The car still goes up an down, and when i start the car when the engine cools , i hear a very loud rough noise for 2 secs. Then when i start the car again there is no noise. This happens only when the engine cools down.
Every help is appreciated.
Tom from Croatia
Old Sep 20, 2020 | 04:16 PM
lkchris's Avatar
'10 CL550, '12 GL550
https://www.mbwholesaleparts.com/con...ontrol-ABC.pdf
Old Sep 21, 2020 | 03:35 AM
cl 550
thank you for the answer, but i did all of the celaning and still is the problem.
Old Sep 24, 2020 | 03:11 AM
07CL550Benz's Avatar
2007 CL550
Did you swap out the accumulators?
Old Sep 26, 2020 | 04:08 PM
pillowshot's Avatar
2007 CL600
What makes you think this is an ABC issue exactly?
The sound and symptoms you're describing to me sounds like a bad timing chain tensioner.
