CL-Class (W216) 2007-Present: CL 500, CL 600
How to remove grille CL550?
Old Dec 28, 2020 | 04:35 PM
Jorma's Avatar
I've removed the top 4 10mm bolts, what do I need to do next? Does it have clips, do I push it forward? Any help appreciated, I don't want to break it!
Mike M
near St. Louis
Old Dec 28, 2020 | 07:23 PM
xabo's Avatar
'20 S63
Mike M
near St. Louis
Should be able to pull-upwards on the grille to remove it.
Old Dec 28, 2020 | 07:25 PM
xabo's Avatar
'20 S63
https://www.google.com/search?client...ozI5gKhtbfYBA9
Old Dec 29, 2020 | 06:33 PM
Jorma's Avatar
Grille removal
xabo, thanks for the link. I had already found that and watched it....he just very slightly lifts up and it comes right out. His must have been out several times before because I've tugged, pulled, and pried and mine doesn't move.
I know I'm going to end up breaking something!
Mike M.
Old Dec 31, 2020 | 07:47 PM
lkchris's Avatar
'10 CL550, '12 GL550
There is difference between facelift models and earlier models. WIS does not have an instruction for earlier models.
Old Feb 10, 2021 | 07:06 PM
kiddkynetik's Avatar
S550
After you remove the four screws, there are clips on the bottom of the grill to the bumpers. I just push/pry the grill toward the engine and it’ll pop off and you can lift it up.
