CL-Class (W216) 2007-Present: CL 500, CL 600
AUX cable in the armrest
Old Nov 18, 2021 | 05:48 PM
iamback's Avatar
'06 Mercedes-Benz CL 500 (C216)
Lightbulb AUX cable in the armrest
Good evening,
I found an AUX cable in the armrest, it seems not to be a standard or option made by Mercedes but an aftermarket interface.
Unfortunately I can't ask info to the previous owner.
I don't know how and where it's connected, I don't want to disassemble the tunnel, there's anyone that have something similar?
I know that the cable is an MMI adapter, I have a source to connect but it doesn't play anything....the AUX menu is enabled in the Command options.
Any ideas?
Thanks in advance.
Old Nov 19, 2021 | 03:39 AM
mvohra's Avatar
w216
Do you have the same connection in the roof of the glove compartment, but it is likely to be just the component itself?
Old Nov 19, 2021 | 04:33 AM
iamback's Avatar
Nope...no others connector anywhere...
Old Nov 19, 2021 | 12:21 PM
mvohra's Avatar
w216
OK, then I am going to hazard to guess that the previous owner has had the MMI connection fitted into the armrest, as it might not have been part of the manufacturing process at the time.
If not already included in the car (which mine was, 2014 model) then you can buy MMI cables that fit onto that connector. There are 3 different endpoints, usb, iPhone and AUX all separate cables.
I use the USB one to connect a USB pendrive so that my music can stream through the car system.
Old Nov 19, 2021 | 01:40 PM
iamback's Avatar
Ok but the point is that I tried to use that connector, I have two adapter (one USB and one Bluetooth made by Invery for this Mercedes plug) but doesn't work....
Old Nov 19, 2021 | 05:12 PM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
FWIW, I bought regular old RCA cables, plugged them into the holes in the glove box, bought an adapter from RCA cables to lightning cable, and listen to music/podcasts/books through my car speakers. I can only control content from my phone or watch, but it's really not a problem for me. The whole setup cost like $7 on Amazon.
Old Nov 19, 2021 | 05:31 PM
iamback's Avatar
I did it in the previous car but in the CL I don't have any RCA, plug, any input in the glove box.
Old Nov 19, 2021 | 06:35 PM
mvohra's Avatar
w216
Make sure your USB device is a pendrive and not an SSD, and it cannot be larger than 32GB or at least in 32GB partitions if the USB pendrive is larger. I had to partition my 128GB pendrive into 4 partitions, and then format each partition a few times before the car decided to accept it.
The car system will see it as a media device and will play your media.
Old Nov 20, 2021 | 04:04 AM
iamback's Avatar
Done it...nothing, it doesn't work...I don't know what kind of interface is, I'll continue to play music from the PCMCIA
Old Nov 20, 2021 | 04:10 AM
mvohra's Avatar
w216
I do still think it is the MMI interface.
Try to repartition it again - I had a few issues with mine too..
Can you post a photo of your final setup.
Old Nov 20, 2021 | 04:12 AM
iamback's Avatar
I tried with many pendrive, tried also to format them in FAT32 / exFAT / NTFS, with or without folder. Nothing.
Old Nov 20, 2021 | 04:23 AM
mvohra's Avatar
w216
What year is the car?
The housing for the cable seems identical to the surrounding area - if so then maybe this is how it came from the factory and therefore an original connector. I don't have that housing in my armrest.
Old Nov 20, 2021 | 04:24 AM
iamback's Avatar
It's a '06
Old Nov 20, 2021 | 04:53 AM
mvohra's Avatar
w216
Mine is 2014 so things would have changed.
Let's do this step by step :
- ensure the pendrive is no bigger than 32GB else partition it so that it conforms. Maybe the older cars took smaller capacity, try 16GB.
- format the partition FAT32 - NTFS will not be read by the car
- place one mp3 music file on the partition
- connect it up to the car
- turn ignition to at least where the dashboard lights up
- look for media interface - I do not think it plays through the AUX option
​​​​​​Post a photo of your final setup. When I go to the car this morning I will take some photos for you.
Old Nov 20, 2021 | 08:05 PM
mvohra's Avatar
w216
Here are some photos from my car. The connection is in the glove compartment and the system reads it as media interface.
If yours still does not work then maybe the software needs updating - that would be the end of my knowledge base.
Old Nov 21, 2021 | 04:39 AM
iamback's Avatar
The software is updated, I done all the updates available just the last week in a Mercedes service. But I don't have the media interface option in the menu...because mine is not a media interface, I know that the official one is only the one in the glove box, mine is in the armrest and "maybe" it should work on the AUX input. The PCMCIA instead works well...
Old Nov 21, 2021 | 05:43 AM
mvohra's Avatar
w216
OK, if you believe it to be an AUX then I think you will need the final connection to be a 3.5mm jack female. Then, using a male to male 3.5mm headphone cable, you will connect a media output, something like an ipod or your mobile phone if it has a headphone jack. When you press play on your external media device it should hopefully play through the car system.
So this is what you need :
- MMI cable with a 3.5mm input
- male to male 3.5mm cable/adapter
- media device, ipod or similar or maybe even your mobile with a headphone jack
I am uncertain if you can get a MMI cable with a male output. If available then that would suffice - you can then connect that directly to your media device.
Ideally you would also need a wireless remote to control your media device so that you don't have to physically touch the ipod or similar. I don't think that would be an option for a mobile device.
Old Nov 21, 2021 | 05:51 AM
mvohra's Avatar
w216
You can also get a USB to 3.5mm, but I am uncertain if that many different types of interfaces/connections would work or even give you the same quality of music output. But I think it would be cheaper than getting the MMI cable with 3.5mm.
Old Nov 22, 2021 | 12:40 PM
nath_h's Avatar
What did the dealer charge for the software update? How many hours billed?
Old Nov 23, 2021 | 03:14 AM
iamback's Avatar
Unhappy
No no...I know what is an AUX with the 3.5 jack, but this is not the case. The MMI interface in the armrest is female, I have an adapter with a MMI male / USB female at which I connected the USB that I told you before, without success.
I have a little Mercedes manual given me with the car that explain how to connect an "iPod" to the car, with a media interface, and there is written to select the AUX choice in the menu...not the media interface. Maybe it appear with the newest software versions.
However, I tried a lot of times with different USB, formatted in different ways, with the Invery adapter that simulate the iPod, but ever without success.
I think that I have to dismount the dash to see where and how this is interface is plugged in to the Comand...
Old Nov 23, 2021 | 03:17 AM
iamback's Avatar
He didn't charge me...The works has been done by my mechanic that is an unofficial Mercedes service, he did a lot of maintenance on my CL so he included in the final cost the upgrade to the AMG cluster, the update of the maps (unfortunately to V15...seems that the V17 has some problems with my unit) and the telematic.
Old Nov 23, 2021 | 03:20 AM
mvohra's Avatar
w216
Then use my last suggestion - get a USB to 3.5mm input and connect an ipod or similar.
Old Nov 23, 2021 | 07:08 AM
nath_h's Avatar
I've been using the 3.5mm setup to my iPhone 11. No headphone jack needed, as I bought a $6 part on Amazon to connect a headphone plug to a lightening cable. I control the iPhone/music with my Apple Watch. Not a perfect setup, but works well enough.
Old Nov 23, 2021 | 03:47 PM
iamback's Avatar
But where do you have connected the 3.5 jack?
Old Nov 24, 2021 | 03:07 AM
mvohra's Avatar
w216
I am going to hazard to guess this to be the connection he has:
MMI with 3.5mm female > 3.5mm male to lightening cable > lightening cable connected to his iPhone charging/audio port.
