help please change abc tandem pump accumulator
hello, I have a cl550, and when it is hot a noise starts to sound around the suspension tanden pump area, I want to change the accumulator that is right on top, but I don't know if it has pressure, if the suspension will fall to the ground and so on . Thank you!
Hi. You can do it yourself, but there are a trick or two. Look at the tread on the SL section. https://mbworld.org/forums/sl-class-...r-replace.html
Good luck
Good luck
