CL-Class (W216) 2007-Present: CL 500, CL 600
w216 ABC valve block repair
Old Nov 3, 2025 | 07:28 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
Originally Posted by Stoyko Mangarov
Hello, How did you remove the epoxy mold from the valves? And are the valves removable so i can replace the O rings since its leaking from its base? Thanks!
I had to cut off the epoxy, and even that was difficult. I used a dremel cutting wheel to cut off portions of it, and then used a chisel to chip away at the epoxy. I can't emphasis enough that these things are built like a bank vault--I am curious how on earth anyone can get in there to rebuild and replace O rings. I suspect the Chinese rebuilders are just cleaning these up, testing, and reselling. I wish Rapa would have been able to share info with me.
Old Nov 3, 2025 | 07:32 AM
nath_h's Avatar
Hi, first, thanks for the fast replies,
So do you know the correct O-ring size for the hydraulic lines that goes into the valve block. I only found the green ones part number and size (8.2x1.78). I cant seem to find the upper ones (black and white).
I'm not seeing that the black one exists as a separate part number. I think you only have to worry about the teal colored one. https://nemigaparts.com/cat_spares/e...71/65v/32/290/
