CL-Class (W216) 2007-Present: CL 500, CL 600
Fault code 90D0 Component switch illumination has short circuit or open circuit
Old Sep 18, 2023 | 02:55 AM
vobak's Avatar
2009 CL65
Hello,
I am having an issue with trouble code 90D0 component switch illumination has short circuit or open circuit on a 2009 cl65. I ran diagnostics with xentry and this is the code that I got. Xentry also gave me a supplemental information on the fault code 90D0 which states possible causes of fault Terminal 58 D and impaired function instrument lighting. I have attached photos of the codes. Can anyone help me in locating terminal 58 D? Cigarette lighter and illumination seems to have the only terminal 58 D with capital. There are multiple terminals 58d with lower case. I am trying to solve dash and switches illumination being very dim at night time. I also traced the issue to N72/1 Upper control panel control unit. When unplugging the 12pin connector 1 the illumination gets brighter. Is there an illumination dim switch control built into the n72/1 control unit? How do you adjust the switch buttons brightness? The ambient lighting switch is on level 5 but the buttons in the whole car are very dim low brightness hardly can see them at night. Any help appreciated, I am tempted to replace control unit N72/1 but I am not sure if that is the problem.
Old Mar 10, 2024 | 05:54 AM
Es221's Avatar
Mercedes W221
Hello i am having same issued. Did you fix it
Old Mar 10, 2024 | 10:55 AM
vobak's Avatar
2009 CL65
Yes I did. It is your cigarette lighter switch in the bottom of the center console. If you open the ash tray the light is probably very dim. The bulb is nearly burnt up.
Old Mar 12, 2025 | 12:33 AM
XIJINPING's Avatar
W221 S500
Thank you for sharing and God bless you.
