Wheel offset question?
Does anyone know if these wheels would fit my 2012 CL63?
Bolt pattern: 5x112
Rim Diameter: 20”
Offset: 35
Width: 8.5” front / 10” rear
I’m mainly worried about the offset. I can’t seem to find out if this offset would work with my CL63 AMG.
Any help would be appreciated!
Those wheels should be a pretty good fit. The offset is about 10mm off from what typically comes on the CL63, so in the event the caliper and spokes are making contact, a simple 10mm spacer would make up the difference. If you are trying to avoid running spacers, we would have to take some measurements to know for certain if the wheel will clear!
All the best!
Tristan Shallow
tristans@vividracing.com
