Rear suspension/height sensor question
When i climb under my car to look at something, i noticed the rear CL65 height sensor is mounted in the opposite direction. One is mounted downwards while the other is mounted upwards. This is very weird as i always thought both rear height sensor is mounted the same direction downwards. Could any of you guys out there confirm this. CL55 should be the same as well.
Could somebody who knows shed some light on this cos i really wanted to know why they mount it in different directions. As the linkages are also different. One is straight with not bent while the other one is bent to one side. Its weird why they have two different sensor mounting.
