CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
03 CL55 - Reprogram for TV Tuner and/or DVD?
Old Mar 19, 2006 | 11:41 PM
RuskiBusiness's Avatar
Old Mar 20, 2006 | 12:27 AM
awiner's Avatar
2003 CL55 AMG
You can add the TV Tuner to get TV signals however your unit in the 2003 is CD based, not DVD. So as for playing DVD's via the unit you can't. If you do add the TV tuner however you can use one of it's inputs to run a DVD player separately.
Old Mar 20, 2006 | 12:38 AM
How can I add a TV Tuner? Will it plug directly into the command or will I need to buy a RGB module? Will I be able to use the steering wheel to change TV channels and have the "dead button" (for euro ver. TV) work?
Old Mar 20, 2006 | 12:02 PM
awiner's Avatar
2003 CL55 AMG
The easiest was is to add the OE Euro tuner which integrates into the fiber bus and will make all controls available. I am not sure all the specifices but you can contact NLBenz on this forum. He sells the parts and programs them too.
You may need a Euro COMAND however to do this. Steve will know.
The other route is a separate non facotry unit, but then your factory buttons won't work with it.
Old Mar 20, 2006 | 04:35 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
[QUOTE=awiner] I am not sure all the specifices but you can contact NLBenz on this forum. He sells the parts and programs them too.
Steves E mail is www.MBENZNL.com
