End of Warranty
My 03 CL55 is approaching end of warranty and I wanted to check with you if you can suggest a checklist I can go through to ensure that i capture all potential problems before the factory warranty expires.
What are the symptoms of the ABC suspension problems? Any other issues I should be looking for?
I appreciate your help and feedback.
Cheers
See if you can get your IC pump replaced before the warranty ends.
Also check if it creaks when going over speed bumps. If so ask them to fix that.
Does the clutch chirp when your SC engages? Ask for the new clutch.
Thanks for the pointers on the IC pump and the clutch; I will attempt to have my dealer replace them if possible.
Many thanks for your reply.......
