How to remove back seat?
2004 CL55 AMG
2004 CL55 AMG: I need to run a Satellite radio antenna into the trunk by removing the back seat to gain access to the trunk, most cars have a release type lever that allows you to pull the back part of the back seat forward to gain access to the trunk from inside the car but I cannot find it anywhere, anyone know how I can do this???? I did find that the bottom cushion easily pops out with a push of a release button but still can't see how to tilt the back section forward...
2004 CL55 AMG
Dealer told me, remove bottom cushion, there will be a 10mm nut on each seat, remove nuts, push up on seat back and you will be able to access trunk.. just FYI if anyone searches for this ....
