CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Need advise
Old Dec 28, 2007 | 11:52 PM
tailshe's Avatar
Need advise
iam abou to get either 2004 cl55 or mabe porsche carrera used
just wondering how expensive can be maintenance of cl 55
now i drive srt4 and another one is mercedes gl450 my wifes
i know changing brakes on some cars can run $5 to $10k, is it the same with cl55
i just dont want to make a mistake, because i can afford the car, just not sure about rest of the little things beside.
Old Dec 29, 2007 | 12:25 AM
DFW01E55's Avatar
'14 ML BT
Brakes on 4 wheels will be 1,200 to 1,800.
Make sure you can get a warranty on the car. Plenty of after market warranty info on this forum.
If not, buy a different car.
I came to the CL55 form a 996TT. It would be impossible to go back to anything less than a 997TT.
The CL55 torque is addicting. I don't drive twisty roads so the MB is perfect.
Old Dec 29, 2007 | 12:31 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
Maintenance wise the AMG car will probably be pretty cheap. I am not sure how the previous post got brakes for $1800. On my SL55 the rotors are about $100 each and pads are around the same, so if you are getting charged more than a couple of hundred for labor, you are being overcharged.
Scheduled services will be cheaper on the AMG, but I would imagine when some of the electronic parts start going bad, the costs will be high.
Old Dec 29, 2007 | 12:50 AM
DFW01E55's Avatar
'14 ML BT
Call the dealer and ask for a brake job ... I bet my numbers are right. The front rotors are 450@ the pads are 310 front (rear?) and labor ... at least 3 hours on the book at $100+ per hour.
What rotors are you getting at $100? I need a set next week.
Old Dec 29, 2007 | 01:11 PM
WSH's Avatar
WSH
2010 CL65
So true....
Had 996TTS and 997TT....great steering and brakes (PCCB) for mtn twisties....but are far less dynamically enjoyable than any AMG CL in straight-line.....(and, stunningly, IMO CL63 ABC is better damped vs bumpy mtn twisties stability vs 997TT's poorly sorted PASM)
997TT turbo lag makes tq delivery nonlinear/non-confidence inspiring; exhaust note music of AMG CL's is some of most enjoyable on planet (often drive w/no stereo on to fully appreciate that addictive exhaust note).....
And straight-line high-speed stability of CL63 is far superior to that of 997TT on real-world US fwys.....
