CL65 Evotech ECU/TCU upgrade experience
Downshifting is critical..leaving in d/s you would lose to many cars as the lag , this is likely why in the vid the M6 jumps you. You need to erase that initial jump and get a lead on him and keep it. I agree with Addicted, dyno mode would be best but at the very least t/c off, seems the 65 has real probs keeping a contact path? Modulate rather than stomp the throttle, and you should stay in front of the M6 all the way to 140, then gearing likely kills the 65
I'll happily run any M6 from this board...The 2008 6.2 liter has bet 380-400 rwhp stock (auto 380-385rwhp)There's vid on this board of CL65 AMG - vs. - C6 Z06 the modded 65 took the Z06, unless the M6 has 3.91 gearing (this 1 apparently doesn't
it aint happenin'
)Last edited by Thericker; Feb 1, 2008 at 04:32 PM.
X100. Now that I'm looking at the video again, its clear that M6 gets a start on you while your car is busy down shifting. At 40mph, I believe you should be in 2nd gear (correct me if I'm wrong here, I have a 7-speed SLK55 and it would be 2nd gear for me). I also think that at 40mph roll, you will have no problem leaving the car in dyno mode and modulating the throttle to prevent unnecessary wheelspin...
Thericker...I also wouldnt have any prob running a c6 although unless modded the c6 z06 would be a better race for me with my mods. Idk how far you are from the op but maybe if you guys end up not too far you could join in on the rematch and get a run in.
Thericker...I also wouldnt have any prob running a c6 although unless modded the c6 z06 would be a better race for me. Idk how far you are from the op but maybe if you guys end up not too far you could join in on the rematch and get a run in.
I don't think more gas is going to do anything, you need to get the car on a dyno, something has to be off with the tune or something else.... probably a bad intercooler pump..... you start pulling hard, then start to drop, i bet it's holding boost back due high IAT's....
that vette which traps 116 MPH hung on tight to the M6..... you should be pulling 125MPH+ which would smoke them.....
what does evotech charge for their ecu/tcu tuning?
would you mind doing a 50 roll as well as the 40? 50 will put the m6 in its best spot from 2nd about 6k rpms. With the m5/m6 being out of your powerband no fun at all. Anyway cant wait to see the results. sl65 was other car I was considering when I got the m6 but I just enjoyed being in the m6 more.
What you neeed to do is down shift with ur pedel shifters in S mode. That way your up shifts will automaticly happen with out the need to use the shifters.
Also do not stomp on the gass as u will just trip traction control.
if this fails ( after having some practice few tries)
then
get a dyno asap
check your pump( possibly data log)
By the way, put your car in M mode, downshift to lowest gear it will allow you to and just punch it. The car will shift at redline by itself. To me the M mode feels like it shifts the fastest. Our cars definitely need a cooling upgrade. Wish I knew which one is best.
