Dealer can't find the problem on the ic pump 03 cl55
and they said i have bad engine and transmission mounts but that's why my cl shakes. they will replace the mounts .how can i prove them that the ic pump is bad since there no warning lights????
Oxygen's recommendation to add power and see if the pump turns on sounds like the best idea. If it does not run, tell the dealership it is bad and they can test it for themselves. Some mechanics at dealerships are pretty dense/lazy and do as little as they possibly can. Make the service advisor feel bad that you had to climb under the car to test it yourself. If he is worth a damn, he will rip the mechanic a new one.
