CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
03 cl55 shakes from the rear after 110 mph
Old Feb 22, 2009 | 10:04 PM
palicl55's Avatar
2008 CL63 AMG 2003 cl55 amg SOLD
my car feels to be too pumpy i feel every single pump in the road plus shakes from the rear after 110 mph like some one lefts the cars and shakes it up and down and my whole body shakes with it???? i pun brand new michlen tires and balanced them still the same problem ?????
Old Feb 22, 2009 | 10:28 PM
benz_addict's Avatar
V12TT
LOL
Old Feb 23, 2009 | 08:41 PM
rtgogo's Avatar
2001 CL55AMG
Check the wheel bearings.
Old Feb 23, 2009 | 10:37 PM
alx's Avatar
alx
wheelbearings? you realize that if you have enough play in the wheelbearings to shake the tires/car the bearing noise will be very obvious...
my vote goes to poorly balanced rear tires. find somebody with a hunter dsp roadforce balancer and redo the balance. it is possible you also have a bent rim which might allow the tire to be properly balanced on a normal (non roadforce) balancer and yet shake once rolling on the road under load.
if not the tires, your driveshaft my be out of balance. it will announce itself as intermittent vibration at low-speed shifts... very common on the cl and s series.
good luck
alex
few cars
Old Feb 24, 2009 | 01:18 AM
whoover's Avatar
'19 E63S sedan
If it's really an obvious up-and-down motion it sounds more like a suspension problem. The ABC lowers the car 35 mm at that speed. Perhaps there's a problem with that system. If you're sure the vibration is mostly vertical have the dealer check the ABC.
Old Feb 24, 2009 | 09:50 AM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
+1....I had a faulty ABC sensor in my rear strut that was giving my car an unstable feeling at high speeds. I had the MB master tech also do an alignment too. No problems after that.
Tom
Old Oct 14, 2009 | 08:13 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Tom
Did they have to change the strut out for the sensor failure?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
