CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Radio/Sat - No Sound
Old May 19, 2009 | 09:52 AM
jeffw666's Avatar
'05 CL65 AMG
So I woke up this am and started the old car... and no sound, zero. Display is lit, I can change from radio to sat, but no sound.
Can someone tell me if it has an external amp and where it might be located?
Old May 19, 2009 | 05:45 PM
jeffw666's Avatar
'05 CL65 AMG
Interesting....... I drove to work...... and then to lunch. It started working again.
Old May 20, 2009 | 12:26 PM
Patentmat's Avatar
That same thing happened to me about a year ago. I have no idea. It has never happened again. Keep your fingers crossed.
Old May 20, 2009 | 01:19 PM
Bo CL500's Avatar
CL500
same here
Old May 20, 2009 | 02:23 PM
awiner's Avatar
2003 CL55 AMG
Sounds like the fiber ring had some sort of confusion/corruption. usually when this happens a reset via the hidden menu will fix this. Or you can just turn your ignition off and then back on to reset.
Old May 22, 2009 | 06:15 PM
jeffw666's Avatar
'05 CL65 AMG
hidden menu???? I have missed something here?
Old May 22, 2009 | 09:44 PM
awiner's Avatar
2003 CL55 AMG
The COMAND units have a service menu. Not sure what the entry code is for your particular year. One the models up to 2003, 1+3+MUTE would take you into it. In 2004 that changed and the code/method was posted here some where years back. Try a search on COMAND MENU.
