Roll call: CL55`s with 80mm TB?
I have tried the VRUS 80mm (limited run of european kits) High idle codes and idle codes. Also running a S600 V12 80 mm and get idle codes and some MAP sensor codes very now and then. Part number MBN 113-1400-104.. Both TB`s required a 1-4 and either a 5-6 /2-3 wire swap.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
